Relay boards SKU 333022/333023 UL 94 V-0 PCB certification documentation
Could you provide a confirmation document (e.g. PDF) stating that the PCB material used in relay boards SKU 333022 and 333023 meets UL 94 V-0? If available, we would also appreciate the name of the PCB laminate manufacturer or a UL file number.
Originally submitted via the contact form on soldered.com on 20 May 2025. Migrated to the forum for community visibility.
The PCB laminate manufacturer is JLCPCB and their UL file number is E479892. Do you independently need a confirmation statement from our side, or would a statement confirming this based on JLCPCB’s UL certification be sufficient?
