Relay module wiring with step-down converter and water sensor
I’m asking about the relay module with sensor we discussed earlier.
Javljam se u vezi onog releja sa sondom sto smo pricali maloprije
Originally submitted via email support on 25 October 2017. Migrated to the forum for community visibility.
You’ll need:
ispričavam se na kašnjenju. U prilogu je slika.
Još Vam treba:
Step-down modul s LM2596S – Soldered Electronics
te naravno žica
Attachment omitted in migration: 20171026_124615.jpg
So I connect the step-down converter to the output of the relay? That’s a bit unclear to me.
Znaci step down spajam na izlazu iz releja ili? To mi je malo mutno
You need to supply power to the relay module first:
  • Connect the 5V output from the step-down converter as power to the relay module (you’ll see the markings VDD and VCC)
  • Use that same 5V to power the water sensor
Morate dati napajanje modulu za relej, pa:
tih 5V spajate kao napajanje za modul s relejom(vidjet ćete oznake VDD i VCC)
tih 5V koristite kao napajanje senzoru za vodu
So the step-down converter goes directly to the sensor module?
Do you have any converters in stock that can handle 12V to 24V at a minimum of 15A current?
Znaci step down ide direktno u modul s senzorom
Yes, that’s correct, exactly as shown in the schematic.
Unfortunately, we don’t have converters that powerful.
Da, tako je, baš kao i na skici.
Ne, nažalost nemamo tako snaže pretvarače
What about the 10A converter in your catalog - would it hold up under a continuous 10A load for about 45 minutes? The load is 120W.
It probably would, but in such a borderline case it might be better to go with a stronger relay or SSR instead.
Vjerojatno bi, ali možda je bolje ići na jači relej (ili SSR) u takvom graničnom slučaju.
