I want to connect an RGB strip directly to a 12V battery using this controller. I know how to connect it to mains power with a 12V 5A power supply, but what do I need to connect it directly to a battery?
zanima me jel postoji mogućnost da RGB traku i sa ovim gore kontrolerom spojim direkt na akumulator (12V), jer ako želim na 220V spojim sa 12V5A napajanjem a kako spojit direkt na akumulator? Unaprijed se zahvaljujem na odgovoru i što mi je sve potrebno za tako nešto.
Originally submitted via email support on 5 November 2015. Migrated to the forum for community visibility.
You can use a male DC connector. Connect the black wire of the connector to the black terminal of the battery, and the red wire to the red terminal. Then connect the connector to the controller, and the controller to the strip. If you don’t have the ability to solder a wire to the battery, you can use alligator clips instead.
možete koristiti ovaj konektor: http://e-radionica.com/hr/muski-dc-prikljucak.html
Spojite crnu žicu konektora na crni plug akumulatora, isto s crvenom, te konektor priključite na kontroler, a kontroler na traku. Ako Vam nemate mogučnosti spojiti žicu na akumulator, možete koristiti aligatorke: 10x kabela s aligator kopčama – Soldered Electronics
