Rotated Inkplate 10 Enclosure
I’ve got an inkplate 10 with an enclosure, i.e. Durable Black Enclosure for 9.7-Inch Inkplate 10 – Soldered Electronics, however I’d like it if I could mount it with the power socket and buttons on the opposite side. Could I ask that you produce 3d printer files with the hanging points on the back on the other side? The software that I’m using can handle rotating the image to compensate for the rotation of the display.
Hello @sammhicks,
Unfortunately we do not provide custom 3D Print and design services. You can use our 3D step files to modify it for your needs, it is available here: Soldered-Inkplate-10-hardware-design/OUTPUTS/V1.3.1/3D printable files at main · SolderedElectronics/Soldered-Inkplate-10-hardware-design · GitHub
Hello @JosipKuci
Are you able to provide the project CAD files that the step files are generated from? The only formats for the enclosure seem to be output meshes found at Soldered-Inkplate-10-hardware-design/CAD/V1.3.1/Source 3D files at main · SolderedElectronics/Soldered-Inkplate-10-hardware-design · GitHub
Inkplate10Case.zip (1.7 MB)
Hello @sammhicks ,
Sorry for the long wait, attached here are the .dwg files for both the front and back panel of the case.
Thanks for posting the .dwg files, that answers sammhicks’ question about the actual source CAD rather than just the export meshes. One thing worth clarifying: are those front and back panels the complete case, or do the side walls and mounting features live in a separate file? Also, since the thread is about rotating the orientation, it would help to know whether the .dwg is parametric or a flattened drawing, because that changes how easy it is to rework the layout for a rotated build.
