Is it possible to get an RS-232 shield for the Croduino Basic or Croduino Basic 2 board? I’ve seen them sold in various places online. I need an RS-232 port to communicate with another device and would appreciate a solution.
Molim Vas da mi odgovorite da li je moguće kod vas uz croduino basic ili croduino basic 2 pločicu dobiti i RS-232 shield koji sam vidio da se na nekim mjestima na internetu prodaje. Trba mi RS-232 port za drugi uređaj pa Vas molim neko rješenje.
Originally submitted via email support on 23 October 2016. Migrated to the forum for community visibility.
Unfortunately, RS-232 shields or modules are not available. Please check your application—you may be able to work with UART if you don’t need negative voltages: Soldered: Open-Source Electronics, Boards, Sensors & Modules – Soldered Electronics You may also need a voltage translator in between.
nažalost nemamo RS-232 shieldove/module. Molim Vas da provjerite Vašu primjenu, možda ćete uspjeti narediti s UART-om ako ne trebate negativne napone: Soldered: Open-Source Electronics, Boards, Sensors & Modules – Soldered Electronics
Možda ćete trebati i voltage translator između..
