Is the AC/DC Mini Power Supply with 5V 700mA output compatible with the RTC Real Time Clock DS3231?
POštovani ! da li jeAC/DC MINI-NAPAJANJE, IZLAZ: 5V 700MA kompatibilan sa RTC REALTIME CLOCK DS3231?
Originally submitted via email support on 16 January 2018. Migrated to the forum for community visibility.
The module can be powered from this power supply.
hvala na upitu. Modul se može napajati iz ovog napajanja.
What module code or name should I use to complete the Real Time Clock DS3231 setup so I can build a complete clock that displays time, date, and other information?
Poštovani hvala vam na odgovoru.Za kompletiranje narudžbe molim da mi za “Real time clock ds3231 naznačite kod ili naziv modula kompatibilnog s kojim mogu kompletirati sat sa drugim dijelom na kojem se očitava vrijeme,datum etc.
L.P.
1..
a..
You can find the code and connection instructions for the RTC DS3231 module here: https://e-radionica.com/hr/blog/2016/02/17/kkm-rtc-real-time-clock/
ovdje možete pronaći kod i upute za spajanje modula RTC DS3231: https://e-radionica.com/hr/blog/2016/02/17/kkm-rtc-real-time-clock/
