RTC module battery requirements and installation
Does the RTC module work without a battery? If a battery is installed, which battery should be used and how should it be oriented? Is it a 2032 or 2025? The contacts look unusual - they seem to short the top and bottom parts of the battery.
Pozdrav, da li RTC modul radi bez baterije? Ako se stavlja baterija, koja baterija i kako je treba okrenuti? Možda 2032 ili 2025? Kontakti izgledaju čudno tj. da kontakti kratko spajaju gornji i donji dio baterije.
Originally submitted via email support on 8 May 2025. Migrated to the forum for community visibility.
The RTC module works without a battery. The battery enables using the RTC in low power mode, but it can also be used normally via I2C. The battery is CR2032.
hvala na upitu, RTC modul radi i bez baterije, baterija omogućuje korištenje RTC-a u low power modu, ali može se koristiti na običan način preko I2C-a. Baterija je CR2032.
