Samsung INR18650-29E and Panasonic NCR18650PF availability and charging
Are the Samsung INR18650-29E and Panasonic NCR18650PF batteries available? Are these genuine batteries? Regarding recommended 18650 charging current, would 1C be appropriate?
Dali imate dostupne baterije Samsung INR18650-29E i Panasonic NCR18650PF?
Dali se radi o originalnim baterijama? Što se tiče preporučenih struje punjenja 18650 dali bi to bilo s 1C?
Originally submitted via email support on 19 April 2019. Migrated to the forum for community visibility.
Both batteries are available and can be ordered. They are genuine and meet their specified ratings.
You can charge them at 1C, which is fairly standard.
hvala na upitu. Obe baterije su nam dostupne i mogu se naručiti. Baterije su originalne i u označenim specifikacijama.
Možete ih puniti s 1C, to je poprilično standardno.
We had an issue with a battery charger and weren’t sure if it was a battery problem. We’re glad to know you stock genuine batteries so we’ll know where to turn for future projects.
I noticed you have your own filament line and saw you offer PETG. I’m curious about your experience comparing it to ABS for printing, since ABS is quite difficult to print and requires care as many factors affect the final print quality.
Da dobio sam odgovor na email, naime imali smo neki problem s punjačem baterije, mislili smo da je možda do baterije, ok sad znamo da imate orginal baterije pa se u budućim projektima znamo kome obratiti :slight_smile:
Vidio sam da imate vlastiti filament, primjetio sam da nudite PETG filament pa me zanimaju vaša iskustva s usporedbom s ABS-om što se tiće printanja, jer je ABS dosta težak za printanje i treba paziti jer dosta stvari utjeće na konačan print. Lp [name removed]
PETG is definitely the better choice. It’s noticeably stronger than PLA and much easier to print. You only need a higher temperature and a sufficiently heated bed—nothing else required.
hvala ti na novostima. Tu smo za baterije.
Što se tiče filamenta, PETG je definitivna preporuka. Primjetno je čvršći od PLA, a također je puno jednostavnije printati. Samo na većoj temperaturi i dovoljno velika temp za heated bed – ništa drugo ne trebate. Poslat ćemo Vam primjerke za probu, ukoliko želite, samo javite adresu :slight_smile:
I’d like to try PETG for comparison with PLA and ABS. I have a Creality CR-10S Pro printer and my setup handles ABS printing fine, so printing PETG should work too. If you’re willing to send samples, the address is in my email signature.
Aha ok, mislim htio bih isprobat PETG samo radi usporedbe PLA - ABS, da setup printera za ABS nije problem tako da bi isto mogao printat PETG, radi se o Creality CR-10s pro printeru, pa ako ste voljni poslat primjerke, adresa se nalazi u signaturi email-a :slight_smile: Lp [name removed]
You’ll have no problem printing PETG on your Creality CR-10S Pro—just adjust the temperature settings.
Samples will be sent on Monday.
bez problema ćete naprintat PETG na svojem printeru, uz samo izmjene temperature.
U ponedjeljak Vam šaljemo primjerke na adresu:
Dolotron d.o.o.
Ziskovec 141
[address removed]
