SGX-4CO I2C communication and code library
I’m looking for code for this sensor breakout for I2C. I’ve searched the repository but can’t find any code. I’ve been running a script polling 2 bits from I2C address 0x49, which a scanner identified, but it’s not working. Is there code available online?
Originally submitted via email support on 26 January 2025. Migrated to the forum for community visibility.
The datasheet for the on-board sensor is available at: https://sgx.cdistore.com/datasheets/sgx/ds-0334-sgx-4no-250-datasheet.pdf
The software library is here: GitHub - SolderedElectronics/Soldered-Electrochemical-Gas-Sensor-Arduino-Library · GitHub
The library includes sensorType structs which configure the sensor: https://github.com/SolderedElectronics/Soldered-Electrochemical-Gas-Sensor-Arduino-Library/blob/d5805979b311ff2f456b3e86d0d7ed/src/sensorConfigData.h#L101
You need to use SENSOR_CO when initializing.
The on-board potentiostat is the LMP91000. Here’s its documentation for configuration: https://www.ti.com/lit/ds/symlink/lmp91000.pdf?ts=&ref_url=https%253A%252F%252Fwww.ti.com%252Fproduct%252FLMP91000
If you need the hardware files, let me know.
