The SHTC3 sensor works correctly until humidity rises above a certain point, then it displays negative values. Here are the readings:
14:52:11.909 → Temp: 26.32
14:52:11.909 → Hum: 32.36
14:52:11.944 → ID: 2183
14:52:16.945 → Temp: 26.52
14:52:16.945 → Hum: -17.02
14:52:16.945 → ID: on board
Board: Arduino Uno
VID: 2341
PID: 95433343933351819051
I soldered the sensor myself rather than using easyC connectors.
Also, can I use 2 sensors on the same Arduino Uno board? Currently the SCL and SDA connectors are occupied.
Mozete li mi pomoci oko senzora SHTC3
naime senzor radi sve dok se vlaga ne digne, pa poslije pokazuje negativne vrijednosti, kao sto je u prilogu
14:52:16.945 → ID: na ploci
BN: Arduino Uno
VID: 2341
Senzor sam lemio, nisam koristio easyC kontakte.
Još jedno pitanje, mogu li na istu ploču koristiti 2 senzora, pošto su mi sada SCL i SDA konektori zauzeti na arduino uno ?
Originally submitted via email support on 24 October 2023. Migrated to the forum for community visibility.
