SIM800L power supply setup with Li-ion battery and buck-boost converter
I need help selecting components and planning how to connect an Arduino with a SIM800L module and a sensor. I’ve seen instructions with diagrams showing different ways to power the SIM module, but I cannot find the necessary components in your catalog. I understand I’ll need a battery, a voltage regulator, and possibly a capacitor to make the battery last longer, especially since the SIM module needs 2A when connecting to the network. Can you recommend a set of components I could order to make this work?
molio bih Vas pomoć pri odabiru komponenti i planiranju spajanja Arduina sa SIM800L modulom i senzorom. Otprilike znam da bi mi trebala baterija, korektor napona i eventualno kondenzator da baterija dulje traje, a i jer SIM modul treba 2A kad se spaja na mrežu… Možete li mi, molim Vas, preporučiti neki set komponenti koje bih mogao naručiti od vas da ostvarim svoj naum?
Originally submitted via email support on 4 September 2022. Migrated to the forum for community visibility.
You can power the SIM800L directly from a Li-ion battery, but when the battery voltage drops below 3.7 V the module will stop working. You can use a charger to recharge the battery and use the module again. To power the module when the battery voltage is below 3.7 V, you would need to use a buck-boost converter, but unfortunately this is not currently in our catalog, though it will be available in the future.
SIM800L koji ste naveli možete napajati direktno s Li-ion baterije npr. https://e-radionica.com/hr/li-ion-baterija-1200mah.html, ali kada Vam napon na bateriji padne ispod 3.7 V modul više neće raditi, no zato možete pomoću ovo punjača Soldered: Open-Source Electronics, Boards, Sensors & Modules – Soldered Electronics napuniti bateriju te koristiti ponovno modul.
I have a general question about powering this module in the field, where it would need to report information only when a sensor state changes. Do you have any advice on how to set up the power supply to last longer in that scenario, and whether a Li-ion battery is the right choice for this use case?
zahvaljujem na detaljnom odgovoru, potražit ću i naručiti navedene komponente pa ih isprobati.
Imam i jedno generalno pitanje za napajanje tog modula u “divljini”, na terenu gdje bi trebao javljati jednu informaciju kad se stanje senzora promijeni: da li bi imali savjet kako bi se u tom slučaju moglo složiti napajanje da traje malo duže i da možda nije Li-Ion baterija u igri?
Zahvaljujem još jednom.
Unfortunately we only stock Li-ion batteries, but there are different battery technologies available, such as non-rechargeable batteries with large capacities. The best advice I can give is to research battery options online.
nažalost mi samo imamo Li-ion baterije, ali postoje različite tehnologije baterija koje su npr. nepunjive, ali imaju veliki kapacitet. Najbolji savjet koji Vam mogu reći je da istražite na internetu.
