TP4056 Li-ion charger Rprog resistor identification
I’m looking at the TP4056 Li-ion charger with protection. I need to understand how it works.
Soldered: Open-Source Electronics, Boards, Sensors & Modules – Soldered Electronics ovaj
[Soldered: Open-Source Electronics, Boards, Sensors & Modules – Soldered Electronics]
Punjač za Li-ion bateriju s zaštitom - e-radionica.com
e-radionica.com
Budući da litijske baterije zahtjevaju poseban režim punjenja, te ih ne smijete puniti na običnom izvoru napajanja, trebat ćete jedan ovakav punjač. Povoljan, te …
Originally submitted via email support on 29 November 2017. Migrated to the forum for community visibility.
On page 3 of the datasheet (https://dlnmh9ip6v2uc.cloudfront.net/datasheets/Prototyping/TP4056.pdf), there is a table showing Rprog values. These are the resistor values for regulating the charging current. On the breakout board, this is the resistor marked 122 on the left side of the charger in the diagram.
[name removed],
na stranici 3 datasheeta : https://dlnmh9ip6v2uc.cloudfront.net/datasheets/Prototyping/TP4056.pdf
u tablici: Rprog su vrijednosti otpornika za regulaciju struje. Na breakoutu to je otpornik na kojem piše 122 na slici lijevo od punjača.
