VGA adapter not working with laptop and monitor
I’ve tried everything you suggested, but it still doesn’t work. Is this adapter intended for Raspberry Pi? I’m using it with my laptop and want to duplicate the display to a monitor.
Hvala na odgovorenom mailu.
Probao sam sve što ste rekli, i dalje ne radi. Da li je taj adapter namijenjen za Raspberry Pi. Ja taj adapter koristim za moj laptop ja bih htio sa laptopa duplicirati na monitor.
Originally submitted via email support on 17 January 2024. Migrated to the forum for community visibility.
I’ve used this adapter with Raspberry Pi and also with regular monitors. Unfortunately, some monitors don’t support the output from this VGA adapter. If you’re looking for a new VGA adapter, try one with additional power supply - those usually work better and work on all monitors.
It might also be a monitor configuration issue. Have you enabled output to the second monitor in your settings?
Ja sam taj adapter koristio za raspberry Pi-jem ali i sa običnim monitorom. Postoje na žalost neki monitori koji ne podržavaju izlaz iz tog VGA adaptera. Ako tražiš novi VGA adapter, probaj neki koji ima dodatno napajanje, oni obično rade bolje i rade na svim monitorima.
Možda je ipak do konfiguiracije monitora, jesi li uključio izlaz na drugi monitor? Ne vidim naše prošle mailove pa se ne sjećam jesam li to spomenuo.
