Water level sensor, MQ7, MQ2, and pump compatibility with Arduino Uno
Are your water level sensor, water pump, and MQ7 and MQ2 gas sensors compatible with Arduino Uno?
Zanima me jesu li Vaši proizvodi: senzor za razinu vode, pumpa za vodu, te senzori plinova MQ7 i MQ2 kompatibilni sa Arduinom točnije Arduino Unom?
Hvala Vam unaprijed na odgovoru
Originally submitted via email support on 11 April 2023. Migrated to the forum for community visibility.
Yes, these sensors are compatible with Arduino Uno. All these microcontrollers are similar, so in most cases they work, especially with simpler sensors like these.
One important note about the water pump: do not connect it directly to GPIO pins because it can draw more current than the GPIO pins can supply. You can connect and control it through a MOSFET instead.
da, senzori su kompatibilni za Arduino Uno. Svi su ti mikrokontroleri slični pa u većini slučajevima može, pogotovo ako je riječ ovakvim jednostavnijim senzorima.
Samo jedna mala sugestija za pumpu za vodu da ju ne koristite preko GPIO pinova direktno jer ona može povući više struje koje GPIO pinovi ne mogu dati. Možete spojiti i upravljati njome preko MOSFETa.
Which MOSFET should I use to connect the water pump to Arduino, and do you have one available? Also, is there another way to connect the pump to Arduino, such as using a relay?
Poštovani, Hvala Vam puno na odgovoru. Također, postoji li neki drugi način spajanja pumpe na arduino npr. pomoću releja ili slično? Hvala Vam unaprijed. lijep pozdrav
We have MOSFETs available for such applications: P-MOS and N-MOS. The difference is whether you need to switch the positive or negative line.
You can also use a relay, but again you must have an external power source to power the relay and pump. Arduino should be used only to control the relay. It is not recommended to power relays from Arduino, especially if there are multiple relays, because they can draw a lot of current that Arduino cannot supply and could cause damage.
Razlika je u tome hoćete li prekidati + ili -. Možete naravno koristiti i relej, samo opet morate imati neki vanjski izvor napajanja koji će napajati releje i pumpu, a arduino koristiti isključivo kao kontroliranje releja. Nije preporučljivo napajanjem iz arduina napajati releje, pogotovo ako ih je više jer može povući puno struje koju arduino neće moći podnjeti i pregorjeti.
