Water pump and solenoid valve connection and control setup
Can I connect a water pump and solenoid valve together, and what tubing thickness should I use?
interesira me da li je moguće spojiti pumpu za vodu i elektroventil kojeg prodajete i koja treba biti debljina cijevi.
https://e-radionica.com/hr/elektronski-ventil-za-vodu.html
Mini vodena pumpa za Arduino projekte i uradi sam – Soldered Electronics
Originally submitted via email support on 21 July 2022. Migrated to the forum for community visibility.
You can connect the water pump and solenoid valve together. The solenoid valve requires 1/2 inch tubing, while the water pump requires tubing with an outer diameter of 7.5 mm and an inner diameter of 4.7 mm.
možete spojiti pumpu za vodu i elektronski ventil koji ste poslali.
Za elektronski ventil potrebna je cijev 1/2 inch-a, dok za pumpu za vodu vanjski promjer cijevi 7,5 mm, a unutarnji promjer cijevi 4,7 mm.
I received the package. Which development board from your product range do I need to control the water pump and solenoid valve with a program?
paket je stigao. Molim Vas da mi kažete koju matičnu ploču iz Vašeg asortimana trebam kako bi mogao staviti program koji će pokretati pumpu za vodu i ventile?
I cannot find a solution for how to connect these two components with tubing. Can you explain how to properly connect the water pump and solenoid valve?
Ne mogu pronaći rješenje kako spojiti te dvije komponente s cijevi za vodu? Molim Vas da mi pošaljete primjer cijevi od nekog drugog prodavača ili objasnite kako pravilo spojiti? (mini pumpa za vodu i elektronski ventil)
Hvala
You can control the components using any Dasduino development board. The Dasduino CORE would work well for your case. Connect the components to the Dasduino CORE using MOSFETs for control. The MOSFETs require a parallel diode connected across the load because when the load turns off, it can damage the MOSFETs. Alternatively, you can use relays instead of MOSFETs, which do not require these diodes, but relays do not offer PWM control capabilities like MOSFETs do.
kako bi ste spojili željene komponente, za kontrolu možete koristi bilo koju Dasduino razvojnu ploču, u vašem slučaju možete koristiti Dasduino CORE https://e-radionica.com/hr/dasduino-core-zenski-headeri.html.
Također navedene komponente spajate na Dasduino CORE koristeći MOSFET-e za upravljanje koji još zahtijevaju da imaju spojenu paralelnu diodu s trošilom iz razloga kada se ugasi trošilo moglo bi oštetiti MOSFET-e. Umjesto MOSFET-a možete koristiti i releje koji ne zahtjevaju prethodno navedene diode, ali oni nemaju mogućnost upravljanja pomoću PWM-a kao MOSFET-i.
