I need to implement I2C communication to the HX711 card (the one with the Attiny404) using “bare metal” C. I can make general read and writes to I2C devices and their registers (I’ve used the NAU7802 in the past). As for the HX711 card, the I2C device address is defined by the on-board DIP switch, but I do not know what register addresses I am supposed to use. I cannot find any documentation about what register addresses that the card is supporting, or what they do. I have read the HX711 documentation, and it does not have any concept of “registers” (everything is done via hardware connections), so your I2C implementation must be completely “home made”. I somehow get the impression that you just set the device address and read 4 successive bytes without writing any register value to the bus, but that would not be “proper” I2C.
I would like a list of the supported I2C registers, and what they do.
