YZC-133 20kg Load Cell specifications and differences from standard load cells
I need a 2D or 3D drawing of the 20kg load cell I recently purchased from you. I need it to design mounting plates and fixtures. Do you have such a document or a link where I could find it?
Molim Vas info o naslovnom proizvodu koji sam nedavno uzeo kod Vas – trebao bih 2D ili 3D nacrt proizvoda zbog izrade montaznih ploca/prihvata. Imate li mozda takav dokument ili link gdje bih ga mogao naci?
Originally submitted via email support on 11 May 2023. Migrated to the forum for community visibility.
I found the dimensions of the load cell online. I’m sending you the image below.
na internetu sam pronašao dimenzije tog load cell-a koji mi imamo. Sliku šaljem ispod.
I purchased two 20 kg load cells from you. One is specified as a high precision load cell (YZC-133) and the other is just listed as a load cell. Could you briefly explain the difference between them or provide the model number of the standard load cell so I can compare their specifications?
zahvaljujem na brzom odgovoru i molim još dodatni info - uzeo sam kod Vas 2 load cella od 20 kg.
Jedan je definiran kao load cell visoke preciznosti (YZC-133) a drugi samo kao load cell.
Molim Vas kratko pojašnjenje razlike ili model običnog load cell-a da usporedim karakteristike…
I consulted with colleagues and found that high precision load cells, compared to standard ones, have significantly less drift over time in addition to better precision. The main differences are in the ratios of cost, reliability, and precision.
konzultirao sam se s kolegama i saznao kako load cell-ovi visoke preciznosti u usporedbi s običnima, osim preciznosti, imaju znatno manje odstupanje kako se koriste kroz vrijeme. Glavna razlika su, dakle, omjeri cijene, pouzdanosti i preciznosti.
